JMP Wish List
Ability to use Workflow Builder ( .jmpflow) files as an Add-In to run from Menu
I create Workflow Builder workflows to ease my repetitive work but I'm not able to use these as Add-Ins. I have to resave as scripts and use these which defeats the idea of a workflow.
Enable the ability to use .jmpflow files in the Add-In menu as shortcuts to running this file type ( currently I have to open the files to run them).
Why is this idea important?
Simplify the Add-In process. Currently I have to resave the Workflow Builder file as a script then use this as the Add-In linked file
2 Comments
Level XIII
You can add a shortcut to a Workflow to any menu - this can also be used in AddIns:
(view in My Videos)
Sarah-Sylvestre
Thank you for sharing this request!
