JMP Tips
Switch Columns (Windows)
Switch columns in a report using the Column Switcher:
  1. There are two ways to open the Column Switcher:
    • In the Report toolbar, click Column Switcher Column Switcher IconColumn Switcher Icon.
    • If you don't see the Report toolbar, select View > Toolbars > Report.
    • From the red triangle menu, select Redo > Column Switcher.
  2. Choose the column that you want to switch from.
  3. Choose the columns that you want to switch to.
  4. Click OK.
If you have multiple columns, use the buttons to animate the column switching or step through each column manually.
Column SwitcherColumn Switcher
