JMP Tips
Clean Up Your Data Using Recode
Use the Recode option to quickly clean up mismatched data in a column or update multiple values at once.
  1. Select the column that you want to clean up or update.
  2. Select Cols > Recode.
Example of RecodeExample of Recode
