JMP Tips
Broadcast Commands (macOS)
Holding down the Command key before selecting a command in a report's menu executes that command everywhere it is valid in the report.
For example, to fit a regression line to many scatterplots in a single report, hold down the Command key then select Fit Line. All the scatterplots then have a fitted line.
Command Key With MenuCommand Key With Menu
