Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
Single Cell RNASeq Workflow in JMP Pro
In this post, there is a series of JMP Workflows that aid in analyzing Single Cell RNASeq data that replicate what use to be done in JMP Genomics Single Cell RNASeq Analysis Workflow.
Included are sample data as well as a Word document that is provided as a tutorial and what you would need to do to make these JMP Workflows work on your data.
Please leave comments below if you have questions or suggestions.
Thanks,
Comments
xubaohui
Hi, Chris, does this work for JMP Pro 17? Thanks.
I have not tried this in JMP Pro 17, but there is a reference to a new feature found in JMP 18 for column formulas so I am not sure it will work.
