Simulation of "Fit All" for Normally Distributed Samples
This script creates random samples from a normal distribution and finds the best-fitting distribution for each one, using the "Continuous Fit > All" option in the Distribution platform.
The output is a data table with one row for each sample, showing the size of the sample and the continuous distribution with the best fit, as determined by lowest AICc value.
See accompanying blog post: Is that the best (distribution) you've got? - JMP Blog
