Simple way to convert multiple .jmp files into .csv files (no modification) in 2 steps
tmyanh1993
Hi all,
My daily work requires me to save many .jmp tables as .csv tables, which takes a lot of time if I use Save as function (can save each file only, need to answer repeated questions from JMP, need to choose directories for each file). I learned from JMP community and composed a simple script. Now it takes only 2 steps:
Step 1: Open all .jmp tables you want to convert to .csv
Step 2: Run the script --> It will ask where you want to store the new .csv files --> Click OK.
The picked directory will be opened with new .csv created; meanwhile, all .jmp data tables will be closed.
That's it. Hope it help.
Comments
Greenhorn
Thanks a lot!!!!!
rc_hertzy
This is a very useful script!  I also need to output Excel files, so changed the file_path and openDTS[i] lines to
file_path = file_dir || one_name || ".csv"; //Use the copied name for the new .csv's name
file_pathE = file_dir || one_name || ".xls"; //Same root for new .xls file
openDTS[i] << Save( file_path ); //Save as csv files
openDTS[i] << Save( file_pathE ); // Save as Excel
