Scripts and images for closing data tables on personal menu
Note that the “close table” scripts will close the data tables without prompting you to save them.  Use with caution!
  1.  Go to View -> Customize -> Menus and Toolbars
Then under toolbars, right click on the last of the list and select “New Toolbar”
JMP will create a new toolbar called “Untitled”.  Click on it to edit the name.
Input the location of the script to be run and the image file you want to use.
Click OK.
Repeat for “close top data table”, “close all except top data table”, “clear row states” and “save row states” scripts.
