Protected LSD
This script implements a method that evaluates the one-way ANOVA for significance. Only if the F-ratio is significant at the specified alpha level will the multiple comparisons of choice be permitted.
Simply open the data table for the one-way ANOVA, then open and run this script. Select the data columns for the Y, Response and X, Treatment roles, select the multiple comparison method, specify the significance, and click OK.
