  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
Image Example JSL
JohnPonte
Staff (Retired)
This file contains example JSL snippets demonstrating how to use the image functionality in JMP. Open the file, select a block of JSL code and run it to see how the image methods work. There are examples for reading in an image from a file or creating a new image. You can resize, rotate, filter or any of the other built in image functions in JMP. You can also see examples of implementing your own JSL to do things, like generate a gray-scale version of an image.
Comments
mike_adams
Very Helpful!
Sri
Hi,
I am trying to add multiple images in a grid pattern. I was able to add the images to a data table. I also have a file location in the data table. Using one of your earlier posts I can create a graph with one image. However, I was not able to pull all images in to the graph using a (x,y) location. Can you help?
Sri
