New to JMP? Let the Data Analysis Director guide you through selecting an analysis task, an analysis goal, and a data type. Available now in the JMP Marketplace!
I usually do summary of all columns. if its the same value i dont catre which line is kept
but to get only the last results... i need to do summary by max date and then join it with the orginal table (it happen alot due to rework or remesure)
