Basic Expression Analysis Workflow in JMP Pro Workflow and Project
The attachment to this post is set of JMP Workflows that replicate the analysis and output of what use to be performed in JMP Genomics Basic Expression Analysis Workflow.  There is example data and JMP Projects that can assist in running these workflows.
A Word document is included describing each workflow and what you need to do in order make the JMP Workflows work for your data set.
Please leave comments below for suggestions or questions.
Thanks,
