JMP Scripters Club Discussions
Mauro_Gerber
Level V
SPC scripting - Why writing information back into a database is important
Problem description - Process is unstable:
  • Influence of time or unknown variable
  • Process moves slowly towards out of spec
  • An incident shift the process
Overview SPC:
  • SPC is like telling a dog to “stay”. Wherever the process is, it should remain in that place.
  • A stable phase should be defined and notify the operator when the process is out of control limits before it’s out of spec.
Problems with SPC:
  • Process screening platform gives a lot of false positives and is therefore not always useable for prioritizing improvements
  • Default SPC control limits on our data are often too strict:
  • When new data are analyzed, the control limits shifts automatically.
  • A change in the process can be overlooked.
The solution should:
  • Generate, store and update individual control limits.
  • Help in setting limits for multiple variables.
SPC scripts
  • The Script generates a table with each variable that contains spec limits.
  • It tries to load existing control limits into the table from the DB
  • It adds scripts to store and set the limits.
Slides and Demo are available on the attachment.
"I thought about our dilemma, and I came up with a solution that I honestly think works out best for one of both of us"
- GLaDOS
Re: SPC scripting - Why writing information back into a database is important
Great demo Mauro, thanks for sharing the script !
