New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit. Register now, free of charge.
Moving from Minitab to JMP and JMP Pro: A Transition Guide - Datasets
Potcner
These are the JMP files containing the datasets used to illustrate many of the analysis tools shown in the Minitab-to-JMP Transition Guide (June 2021).
Comments
shampton82
Where can I get the guide?
philramsey
Where does the guide itself reside, so I can read it and more important recommend it to others!
DaeYun_Kim
@shampton82 @philramsey
You can download transition guide from below link.
Moving from Minitab to JMP: A Transition Guide, Version 2
