New to JMP? Let the Data Analysis Director guide you through selecting an analysis task, an analysis goal, and a data type. Available now in the JMP Marketplace!
Created:
May 13, 2015 05:44 PM
| Last Modified: Mar 24, 2017 6:46 AM
Learning 3 - Basis Statistics in JMP.jrn
Learning 2 - JMP Navigation and Use Part 2.jrn
Learning 1 - JMP Navigation and Use Part 1.jrn
The journals used by Mia in the JMP 13 Getting Started with JMP webcasts, recorded Sept 2016. Journals provide links to data in the Sample Data Directory.
