  • See how to interactively organize and restructure data for analysis. Register for May 29 webinar, 2pm US ET.
Design of Experiments Example: A Two-Way Split-Plot Experiment
marie_gaudard0
Staff (Retired)
In this example, you construct a two-way split-plot design and then analyze the resulting data.
A two-way split-plot (also known as strip-plot or split-block) design consists of two split-plot components. In industry, these designs arise when batches of material or experimental units from one processing stage pass to a second processing stage. To use a two-way split-plot design, you must be able to reorder the units between stages
