JMP Pro Library
Generalized Regression Presentation - 5-1-2024
(view in My Videos)
Presentation from JMP Systems Engineer Scott Allen on using Generalized Regression in JMP Pro. This presentation was part of our May 2024 Central Region JMP Pro User Group meeting.
The Generalized Regression personality is useful for many modeling situations. This personality enables you to specify a variety of distributions for your response variable. Use it when your response is continuous, binomial, a count, or zero-inflated. Use it when you are interested in variable selection or when you suspect collinearity in your predictors. More generally, use it to fit models that you compare to models obtained using other techniques.
Attached is the JMP Journal that Scott used in his presentation.
