JMP On Air
The JMP Workflow
(view in My Videos)
In this episode of Things I Wish I Knew When I Started Using JMPSystems Engineer Mike Anderson introduces the 4-step JMP Workflow, an easy way to create and understand JMP reports. The process is simple, but powerful. Step 1 – Make a report. Step 2 – Look at the graph; are you seeing what you want to sharwithin five seconds? Step 3 – Ask questions about what you see. Step 4 – Push the Answer Button.” Using data from Futurama, one of his favorite shows, Mike demonstrates how easy, and effective, the 4-step JMP workflow can be.
