  • See how to use the JMP Marketplace – Free tools to expand JMP capabilities. Register. July 10, 2 pm US Eastern Time.
JMP On Air
Text to Columns, Part II
(view in My Videos)
Sometimes a column contains text that would be more useful if it were stored as columns of data. In this segment of Ask the Data Doctor, JMP Systems Engineer Brady Brady expands on an earlier episode by continuing this discussion around converting text to columns. The Data Doctor shows us more ways to use JMP's Text to Columns tool to generate new columns from text. Using a variety to data (including newspaper, trucks and order data), Brady will also give you tips for using – and display for your viewing pleasure – the real power and flexibility behind JMP’s data filter, how to create and select indicator columns, combine columns and more.
