JMP On Air
Setting Preferences
(view in My Videos)
When inheriting JMP reports, sometimes they won’t look like the way you want, or need, them to. Luckily customizing is easy in JMP. In this episode of Tip of the Day, Pete and Mary show you how adjust your preferences to modify your report and how to make those changes permanent, so that you don’t have to modify them every time you generate the report.
After watching this session, follow-up with a guided example from our help documentation.
