  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
JMP On Air
Recode Review
Brady Brady, AKA the Data Doctor, is back to talk about all things Recode. A great tool for cleaning up messy data, Brady gives us a detailed look at the Recode platform in JMP 15. In addition to high-level discussions of some common Recode tasks, Brady hits on some lesser known and advanced features of the tool.
Comments
szdaizha
Could you please share the JMP file? Thanks!
ktbrickey
This is great! Thank you for sharing. I learned a lot!
@brady_brady Are the JMP data tables featured in this video available somewhere?
mostarr
I am  new to JMP, somewhat, and I don't even see the Recode text option when I right click on a data column. I'm not sure why. I need it to find if there are entry errors in certain columns.
(I can't share a screenshot because it contains proprietary information, but it doesn't really add any value beyond displaying what I am describing the problem to be, in any case.)
Thanks,
Mike
mostarr
Hmm, there must be a version difference in the feature, as the tutorial video I saw says to right click on the column name in the left window, whereas for me (I figured out) it works to right click on the title of the column in the main data window. So technically it works, though it would be appropriate to add a note to the tutorial video saying that the feature has been updated in new versions of the software.
Mike
