JMP On Air
One-Way ANOVA
(view in My Videos)
Are higher priority jobs being completed more quickly than medium or lower priority jobs? Is breaking strength the same between different processes? Do different dosages of the same type of drug affect patient pain levels. These are the sorts of questions one can answer using one-way ANOVA. The one-way analysis of variance (ANOVA) is used to determine whether there are any statistically significant differences between the means of two or more independent groups. JMP Systems Engineer Olivia Lippincott shows us ANOVA in action using JMP.
If you have a larger appetite, sink your teeth into and feast when you head over to the statistics knowledge portal for some additional information.
