JMP On Air
JMP User Community
(view in My Videos)
@Ryan_Gilmore explains why the first place you should go as a user for JMP questions, resources, and Add-Ins is the JMP User Community.
Regardless of where you are in your JMP journey, the JMP User Community is for you. Hosted by the JMP Division of SAS the community is designed to facilitate the exchange of technical information related JMP products, services and the sharing of best practices. In this session you’ll learn how you can solve problems, explore JMP resources and get the add ins you need to be the best JMP user possible.
