JMP Library
Which Model When?
Which Model When?
The models you use depend on your data, the questions you are trying to answer and the problems you want to solve. Work through case studies that illustrate how to identify, fit and evaluate models that might be most useful in achieving your analysis goal.
(view in My Videos)
Resources
This is part of the Get Going with JMP series.
