JMP Library
Unlocking the Power of Graph Builder
Unlocking the Power of Graph Builder (JMP 17, 2023)
JMP produces specialized graphs and plots with supporting tables, statistics and maps. The drag-and-drop interface is intuitive, lets you get started quickly and gives you a ribbon of options to use to select alternate graph types. Advanced features allow you to control format and appearance to create persuasive visualizations. See several case studies that demonstrate different techniques to create compelling graphs that uncover relationships in your data and identify areas for further analysis. This topic covers using obvious and hidden graph zones; building uncommon graph types; and fine-tuning axes, colors, gradients and legends.
(view in My Videos)
If you are looking for the Unlocking the Power of Graph Builder using JMP 16, that video is here.
Resources
This is part of the Get Going with JMP series.
