JMP Library
Tip: Using the Get Script Message to Learn Code
When you send the Get Script message to any JMP object, what's returned to the log is a script that will create an identical object. So this is a great way to learn the proper syntax. For example, you could add a property to a column interactively, and then send the Get Script message to get the code that creates that property. You can then use that code, or a modified version of it, in your script.
