JMP Library
Stepwise Regression
Use to perform automated variable selection in multiple linear or logistic regression models. The method is particular useful when there is a large number of candidate explanatory variables.
Stepwise Regression
  1. From an open table, select Analyze > Fit Model.
  2. Select a response variable from Select Columns and click Y.
  3. Select predictor variables and click Add.
  4. If desired, select a validation column (JMP® Pro only).
  5. Select Stepwise from the Personality drop-down menu.
  6. In the resulting Stepwise Fit window (below):
  • Select a Stopping Rule.
  • Select the step Direction (forward, backward or mixed).
Car Physical Data.jmp (Help > Sample Data Library)Car Physical Data.jmp (Help > Sample Data Library)
  • For Forward regression, remove all terms, then click Step or Go.
  • For Backward regression, enter all terms, then click Step or Go.
  • The Mixed direction is only available with the p-value stopping rule.
  • To run the model shown in the Current Estimates table, click Run Model.
    JMP generates the Fit Model report.
  • See the Multiple Linear Regression or Multiple Logistic Regression one-page guides for more details.
Visit Fitting Linear Models > Stepwise Regression Models in JMP Help to learn more.
