JMP Library
Powerful Tools for Data Management
In any analysis problem, most of your time is spent preparing the data for analysis. JMP makes this process easy with powerful data manipulation capabilities.
See how to use JMP 17 or JMP Pro 17 to import data from PDF, JSON and text files; add spec limits as a column property; rearrange data; recode problematic values; and filter and graph data.
Mac demo:
(view in My Videos)
This is part of the Get Going with JMP series.
Resources:
