JMP Library
Navigating the JMP interface in Microsoft Windows
This guide provides information on the Windows JMP interface. For information on creating a new data table, opening data tables, and finding help within JMP see  Opening JMP and Getting Started.
The Home Window
  • When you first open JMP, you’ll see the Tip of the Day window.
  • You’ll also see the JMP Home Window, which includes:
    • Menus and toolbars (top).
    • Recently used files (on the left).
    • All open data tables and windows (on the right). Hover over an item in the list for a preview.
  • The JMP Starter, Home Window and other features can be accessed via the View menu.
JMP Home WindowJMP Home Window
Navigation
  • Data tables display thumbnails of open reports (bottom left).
    Hover over a thumbnail for a preview.
  • Each data table and report provides icons (bottom right corner) to facilitate navigation between windows:
    • Return to the Home Window (or, click CNTL – 1).  gail_massari_3-1752686882341.png
Data table open reports bottom leftData table open reports bottom left
Tips:
  • Each window has a JMP menu and toolbar.
  • To view a hidden menu click Alt, or hover on the report window where the menu would normally appear.
  • To have menus and toolbars always display, go to File > Preferences > Windows Specific and change Auto-hide menus and toolbars from Based on window size to Never.
  • The JMP Home Window and Tip of the Day appear by default when JMP is opened. To change the default windows, use File > Preferences > General.
File>Preferences>GeneralFile>Preferences>General
