JMP Library
Keep Going with JMP
This course is the older (JMP version 18) and slightly longer (45 minutes of videos instead of 10) version of the Getting Started with JMP. Choose this if you want to go a little deeper in your introduction to JMP.
In these videos you'll learn about:
    • the four components of the JMP data table
    • manipulating and managing data by recoding data, adding column properties, and creating formulas
    • summarizing and joining data tables
    • importing data into JMP
    • using JMP analysis and graphing platforms such as Distribution and Graph Builder
    • saving scripts as part of a data table file, so you can easily recreate your analyses and share them with colleagues.
Download the Getting-Started-data.zip file linked above to follow along with the demonstrations. The Big Class.jmp data file is used in the introductory videos.
Erratum     In the video “Creating a Summary Table and Changing Column Names,” the narrator says that linking the Summary table means changes in the original table will be reflected in the Summary table. Unfortunately, that’s not the case! (It is true for linked Subset tables, though.) Changes to the data in the original table will result in the Summary table being disassociated from it. We apologize for the error!
Comments
NatchanokC
Is this version still available?
It shows the following on my side.
Not Found
The requested URL /jmp-courses/GSOD25/ was not found on this server.
