JMP Library
How Can I use JMP for Statistical Process Control (SPC) in the Chemical Inudstry?
Using data for a process where multiple materials are feeding in from different streams and then going through a reactor, see how to monitor process stability, get an alarm when the process is out of spec and uncover which parameter(s) relate to the problem.
This workflow includes using:
-control charts
-process screening and
-model driven multivariate control chart
(view in My Videos)
