JMP Library
Enhancing Interaction with Platforms
Your script can enhance the analysis by adding a column switcher or a local data filter to the platform used by your script. So, you can include the Local Data Filter argument or the Column Switcher argument in the launch message to add these features when the platform is launched. For example, the code shown here uses both the Local Data Filter and the Column Switcher arguments as part of the platform launch. Alternatively, you can add these features by sending either the Local Data Filter message or the Column Switcher message, or both, to the analysis layer after the platform is launched.
