JMP Library
Designs of variable resolution robust to non-negligible two-factor interactions
Authors
Ryan Lekivetz (1) and C. Devon Lin (2)
Affiliations
(1) JMP Statistical Discovery LLC
(2) Queen's University
Journal
Statistica Sinica
Date Published
2016
Abstract
In some experimental situations, there is a natural grouping of factors. Prior knowledge may indicate that active two-factor interactions only occur within groups of factors. Designs of variable resolution (Lin (2012)) were introduced for such situations. However, main effects from one group in a design of variable resolution may be aliased with non-negligible two-factor interactions from another group. In this article, we introduce robust designs of variable resolution which ensure main effects are robust to non-negligible interactions. Constructions are provided for a number of situations. Some existence results are given as well.
Citation
Lekivetz, R. and Lin, C.D., 2016. Designs of variable resolution robust to non-negligible two-factor interactions. Statistica Sinica, pp.1269-1278, https://www.jstor.org/stable/24721275.
