AMcPartlane
Visitor
Duplicate Patients
Dear all, Have you used SAS JMP Clinical to detect professional / dupliate patients across a drug portfolio or across the same indication covering multiple Sponsors or drugs? If so, please could you provide some advice on how this can be done?
thanks
Angela
Re: Duplicate Patients
Hi Angela,
You could combine studies within JMP Clinical and use the same Data Integrity reports to find duplicated records or clustering of various findings, events and/or interventions to see if any subjects seem way too close in distance to each other than the others. Given that professional patients will try to fake some of their vitals (height, weight, etc.) those types might not be as useful and could be removed from the reports in the options before running the reports.
Does that help?
Chris Kirchberg
Chris Kirchberg, M.S.2
www.jmp.com
