Data Is a Myth Buster: Alfredo Lopez Navarro, Telefónica, on the benefits of empowering everyone in your organization to use statistics to make decisions.
“… the tension gets reduced because once you put the models and the data on the table, politics play a different part. Still they are important, but it's more technical, right? So, people get more relaxed and focusing about the important stuff. In the long run, this is much better for any corporation.”
For more insights on building a culture of analytic excellence, watch this panel and case study
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
