JMPer Cable Blog
AllisonHines
File Exchange transitioning to JMP Marketplace
Since its launch in October 2024, the JMP Marketplace has served as a central hub for secure, quality-controlled JMP extensions. To offer you the best possible experience, we're streamlining our platforms and phasing out the File Exchange.
Here are the key dates to remember:
  • July 7, 2025: The File Exchange will no longer accept new submissions.
  • End of 2025: The File Exchange will be removed permanently.
We encourage all users who want to share their JMP extensions to publish them directly to the JMP Marketplace. As long as your extension meets our guidelines, we'd love to see it there! Please note, JMP reserves the right to remove any content from the JMP Marketplace at our discretion.
How to submit your extension to the JMP Marketplace
Ready to share your innovative extensions with the JMP community? We've made the submission process straightforward. You can find comprehensive information on our guidelines and the JMP Marketplace validation process here.
To submit your extension, simply complete this form.
Here are the minimum requirements for submitting an extension:
  • The extension file as a .zip: This can include an add-in, journal, data connector, dataset, or other relevant files. If you're submitting a single .jsl file, we highly recommend consolidating it into an add-in.
  • At least one image: A screenshot illustrating the extension's interface is perfect.
  • Metadata information: This includes details like compatible hosts, JMP versions, and JMP product compatibility.
  • A clear description: Outline how to use your extension effectively.
If you have any questions about the JMP Marketplace submission process or testing, don't hesitate to reach out to us at [email protected].
Last Modified: Jun 26, 2025 7:54 PM
Comments
