jeffmoore
Window Manager
This add-in allows you to easily manage your open JMP windows whether you use Windows or Mac.
   - You can hide, show, minimize, or close your JMP windows.
   - You can act on multiple windows at once.
   - You can sort and filter the list of windows shown in the window manager.
Comments
Audrey_Shull
Very useful utility, particularly on Mac where the functionality in the Home window isn't quite as rich. I use it to quickly and easily clean up my desktop.
gina_renner
I get an error when trying to install this Add-In.  The error I receive is "Unable to install JMP Add-In - no addin.def file was found in the root of the .jmpaddin file."  Can anyone explain why?  Thanks!
rwdavis513
Thanks for the addin! I look forward to giving it a try. I frequently end up with 5-10 files open per project and dozens of graphs. Sometimes I need to switch between projects in the middle of my analysis. Any suggestions on how to use this addin with the projects platform?
Article Tags
