This add-in allows JMP to make sounds that will make you think. Works best on Mac.
Usage:
1) Ensure your speaker volume is at a good level.
2) Under the Add-ins menu, select Thinking Sounds.
3) In the window that pops up, click Make Sounds.
4) Listen, and think. (You can also view the log to see the sounds.)
It makes me think, "Why?" :) Is there some science behind it? Genuinely curious.
