JMP Add-Ins
Download and share JMP add-ins
Switch to short or long names
When you import from SAS or SPSS, you have the option of using the names or the labels, but both are stored in column properties. If you later want to switch to use the short names (SASName or SPSSName) or long names (SASLabel or SPSSLabel), this addin will do it.
Comments
Would love this as a right click option like toggling value labels :)
