Split and Set Spec Limits
Purpose of this tool is to let JMP users split long (stacked) data and set specification limits directly from the original data if data is in correct format. Tool requires data table in long/stacked format, with some of the following columns:
  • Column for measurement name
  • Column for measurement data
  • Optional grouping columns
  • Column for Lower Limit
  • Column for Upper Limit
  • Column for Target
  • Optional column for X-axis if you want to plot immediately after splitting is completed
Selections:
Limits table:
Result table with column properties set:
Graph if X-axis column is provided:
Understanding which column belongs where is a bit finicky, and I might add some tips at some point. You can post improvement ideas here here or in open issue in GitHub - Split and Set Spec Limits .
This tool is part of JMP-Tools I have been working on for some time now and I will release more Add-Ins when time permits in JMP Community.
