New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit. Register now, free of charge.
Semiconductor Toolkit
(18Aug2019) - A note from the author
Hi, All!  It's time to start thinking about a new version of the STK... I've got some things that I'd like to do, but I also want to hear from those using the tool.  If there's something you don't see or think could be improved - drop me a private message.  I do plan to look through the comments section as a sanity check, but I may miss something. So, if it's important, do send me a private message.
 THE SEMICONDUCTOR TOOLKIT (VERSION 2)
The Semiconductor Toolkit is an attempt to answer the need from the semiconductor industry for specialized visualizations and reframing of existing JMP capabilities.  On its initial release, the toolkit contained tools for generating patterned and unpatterned wafer maps, annotating existing graphics with wafer geometry, and a semiconductor specific frontend to the Hierarchical Clustering with spatial measures option.  It has now been expanded to include analytical methods for exploring die defect data, making comparisons between wafers, and a collection of tools and utilities contributed by the user community. The toolkit is intended to be a collaborative and living effort by interested parties.  Constructive criticism, bug reports, and capability suggestions are welcome and encouraged.
SYSTEM REQUIREMENTS
The add-in is for version 12 and newer of JMP and JMP Pro.  The add-in will check which version of JMP it is being added to and show only the methods available on that installation.
UPDATES
  • (2016-08-22) Version 1 released.
  • (2016-11-03) Corrected bugs found by @ragnarl.
  • (2016-10-14)  Added a note about the next release to correspond with the launch of the new community site
  • (2016-09-26)  Added screenshots and descriptions for each tool.
  • (2017-11-01)  Version 2 released.  WELL, THAT TOOK LONGER THAN EXPECTED... It represents a complete overhaul of the Add-in.  A number of new tools were added, including tools for handling wafer maps for patterned wafers and methods for comparing wafer maps with dissimilar sampling patterns.  Under the hood, the application was completely rewritten in the JMP Application Builder.  I also standardized many of the methods in the original Add-in to ensure consistent performance across the platforms.  A proper help manual is also included and will be expanded as time allows.
  • (2018-02-15)  Fixed a couple of bugs in the initial release.
  • (2018-02-23)  Bug Fix.
  • (2019-09-24)  Fixed a couple of bugs (one related to using JMP with non-English Languages and one issue in preparation for JMP 15 release).
  • (2020-01-12)  Fixed the "yval" bug in the quick patterned map feature.
THE TOOLS
Annotation Tool adds markers for the wafer and exclusion edges to an existing graph or series of graphs in the same window.  If the die geometry is known, markers for the die layout can also be added.
Mapping Tool Set > Patterned Wafer Map uses die indices and a response variable to generate a patterned wafer map.  The platform also provides summary statistic capabilities for the wafer map.
Mapping Tool Set > Bare Wafer Map uses coordinate information and a response variable to create a bare wafer map.  The tool provides information about the quality of the fit for the smoothing algorithm used.  The tool currently supports Neural Network models - one type in JMP and two types in JMP Pro.
Mapping Tool Set > Use Geometry creates Shape Files for JMP to use in the Graph Builder Platform.  Due to the differences in IT policy, the files are generated on the user's Desktop and it is left to the user to move these files to the correct location in the file system.  These locations can be found on page 308 in the JMP 13 book "Essential Graphing."  This book is included in the JMP install and can be found under Help > Books > Essential Graphing in JMP.
Mapping Tool Set > Use Stepper Map creates Shape Files for JMP to use in the Graph Builder Platform as with the Wafer Map Generator.  This tool uses a table of coordinates to generate the map.  As with the Geometry Tool, see the JMP documentation for how to use the generated files with Graph Builder
Mapping Tool Set > Use Die Index uses a table of die indices to generating approximate wafer map shapefiles.  As with the Geometry Tool, see the JMP documentation for how to use the generated files with Graph Builder.
Analysis Tool Set > Cluster Defects is a front end for the Hierarchical Clustering Platform with the spatial measures option used.  This front end recasts the general terms used in the Hierarchical Clustering Platform into terms that are more familiar to the semiconductor industry.
Analysis Tool Set > Explore Patterned Data generates a report that supports the exploration of binning and test data.  It provides the same summary statistics as the Patterned Wafer Map tool with additional drill-down capabilities.
Analysis Tool Set > Compare Wafer Maps compares two wafer maps with dissimilar sampling patterns, i.e., different products on the same tool or process.
Utilities Tool Box > Attach Table Limits is a port of the tool by @txnelson.  Detailed documentation for its use can be found here.
Comments
Ventily
Hello Mike,
using jmp16 the semiconductur toolkit seems not to work properly (at least for my installation). Is there a recent update which covers jmp16 as well. This would be so helpful,
thanks & kudos for your effort so far,
Ventily
@Ventily - Hi!  Thanks for trying the toolkit.  The JMP14-15 add-in works just fine on everything up to JMP 18. Can you give some more details one what you're seeing?
M
Residentx
@MikeD_Anderson Can you remove this or update it?
@Residentx  - no.  it's still valid.
twulz555
Hi Mike,
Thank you for creating this Toolkit! I find it very helpful. By any chance, do you have any recommendation for modifying the graphs for those of us running 100mm wafers with a primary flat?
With regards,
Tom Wulz
@twulz555 - Hey!  At the moment you can update the radius for 100mm wafers without issue. The documentations shows  where the settings are to do that.  The issue of flats is something I've got in the next release (whenever I can carve out some time to finish it off...).
Best,
M
twulz555
Thank you for your timely response, Mike! I wish you the best.
hogi
Map generation is very useful. It makes the map shapes easy to handle.
Unfortunately, if there are many dies on a wafer, it takes a long time to generate a map (already for 100x100 it's several minutes)
Are there activities planned to improve the speed?
@hogi - waiting on some bugs to get fixed in Graph Builder to roll out a new (faster) code base for the addin.
Gasquet
Hey Mike,
Does the current version include the capability I shared with you to upload a Klarf file from a defect inspection tool?  In the description talking about defect clustering, It sounds like you did integrate that code.  If not, please remember to reach out when you plan to carve out time for a new version so I can help get this capability integrated. I did discover some bugs that were fixed since sharing the code with you.
Hello Mike,
I am looking for the Semiconductor Toolkit_V2-1.jmpaddin file. It is not available on the Toolkit main page where the PDF manual and installation files are.
Regards,
MR
Hey @PivotalWhale327 The only two versions of the add-in are available at the top of the page.
