JMP Add-Ins
Save Script to Data Table JMP Add-In
The 'Save Script to Data Table' JMP Add-in is designed to save the contents of the current script window to a data table.
Usage:
     From a script window, click the Add-Ins menu and select Save Script Window to Table. If
     multiple tables are open, the user will be prompted to select a table for the script to
     be saved. A new table script named 'Script Window' will appear in the selected data table.
