Jmp based free SPC program.
Uses excel file as a database.
Perfect for Labs.
Manual is included.
hi
we need more information about your Add-ins SPC
Tom -trying to use this addin. It's not clear tome how to point this addin to a different limit.jmp file than what is in the default. Can you indicate how this is done?
Richard
Hi @richard_steger0 .
You can click "Show/hide limits" button to modify a Limits.jmp table.
If you prefer to edit/replace the file, it is in the addin folder.
You can navigate to the folder by clicking "Open Excel DB" and then go one level up to the parent folder.
Let me know if it works for you
Hi Tom, neat add-in for SPC, is there any chance of sending me the script underlying the addin as a starting point for me to develop my own version?
Thanks
Nicola
Hi @brammern. You can download the jmpaddin file. Then change the extension to zip, extract it and a file named "Run SPC.jsl" is a main script file.
No recommendations found
