The following Add-In allows users to easily color-code rows of a data table using a data filter. As you decide on selection conditions and colors a legend will populate, which you can save to the data table upon completion of your table coloring.
When you use the Add-In you may notice that the tool also adds functionality to remove colors from the table/legend retroactively attempting to restore a previous coloring if possible.
I noticed that JMP did not make if very easy to color rows, so this tool was developed to make the process easier and more intuitive.
