This add-in uses JMP mixed model platform to do stability / shelf-life analysis while considering random batches. Statistical details for the analysis are found here: Mixed model stability analysis
JMP Version: JMP Pro 17 or newer
Operating System: Windows or MacOS
13Nov2024: Updated Add-in to correct a small issue with the displayed equation under the envelop setting.
Hi Mike, thanks for the nice add-in. However, there's a line indicating that there are reported errors in my graphics scripts. Can you help me on this?
