Browse apps to extend the software in the new JMP Marketplace
Propensity Score Matching
This is translation of the Japanese version of the add-in. The original source material can be found here: https://www.jmp.com/content/dam/jmp/documents/jp/support/propensityscore201412.pdf
I've included translations (google translate) of the documentation included in the add-in.
Comments
Lu
hello
I wander whether someone has the same output problem using this add-in.
The propensity score Add-inn does not produce a matching column and give an error when I check the "Logit conversion" because the values are out of the 0-1 range.
Is it possible that it is because I use Characters as "data type" for my nominal values instead of numerical data type, both for my "Y" and "X" variables??
When I run the Add-in with the simulated table included with the Add-In I have no problems with the table output.
regards,
Lu
