JMP Add-Ins
Download and share JMP add-ins
Plot Right Censored Values (Life Distribution)
This add-in adds non-selectable markers (red triangles) at the times of right-censored values to an existing Life Distribution Report.
NOTES:
  • The addin runs on the current data table and Life Distribution report.
  • The addin only supports one by-group; if more than one “By” column is desired, concatenate the columns of interest and use the new column as the “By” column when running the Life Distribution.
Folow this process to use the add-in:
    1. Open or select the data table of interest.
    2. Run Life Distribution platform and get the report.
    3. Run the addin.
Cheers,
Brady
NOTE: Modified in June of 2025 to support a change in the display tree structure.
Comments
Azi
Hi,
I installed the above mentioned Add-in. But it doesn't function. Is there any alternative way?
Cheers
Azi
Arief
Hello,
I installed the add-in file (above), however it does not function. is there other way to make a censor marker in Survival Curve?
Thank you
