Browse apps to extend the software in the new JMP Marketplace
Menu Item to Reopen Last Closed Report
julian
(Note: This Add-In requires JMP 16 or later to function)
Purpose: This utility Add-In provides a menu item to quickly reopen your last closed report in the exact state it was in before closing.
Use: After installing the Add-In, select Add-Ins > Reopen Last Closed Report
This Add-In requires JMP 16 or later because it uses the JSL that the Action Recorder has saved to the Log.
