JMP Add-Ins
JMP Add-In that plots uncertainty in X and Y values
A common requirement is to plot and review bivariate data when there is a measured or assumed uncertainty in both the X and Y value. For example, such uncertainty might be measured as a standard deviation.
Using a table like this:
and assigning columns to the following roles:
this add-in produces a plot like this:
in which the uncertainty of each point is shown by the 'cross hairs'.
