‘New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit – register now, free of charge.
Extended Summary Add-in
This add-in is meant to extend the number of statistics offered in the Summary platform, by including most of the additional statistics found in the Distribution platform. It also adds the Rank statistic, and supports trimming and Winsorizing for any statistic.
Here are the statistics supported by the add-in. For each, the data can be trimmed or winsorized, as well:
Comments
seung275
Why "Mode" is not working at Non-numeric column? It disappoint me.
hogi
Interesting.
Why is this not part of JMP?
